My 1st Philco Restoration - 46-350
Yea. Good point about the space and finding a good place to vent off the heat
from the sand resister. As to the switch, it looks to be in good order.
Anyone ever had problems with the tuning cap (air)?
My 1st Philco Restoration - 46-350 - by Freddy - 12-04-2011, 04:41 PM
Re: My 1st Philco Restoration - 46-350 - by Arran - 12-04-2011, 08:53 PM
Re: My 1st Philco Restoration - 46-350 - by Freddy - 12-04-2011, 09:22 PM
Re: My 1st Philco Restoration - 46-350 - by Arran - 12-04-2011, 10:08 PM
Re: My 1st Philco Restoration - 46-350 - by Arran - 12-05-2011, 03:24 AM
Philco 91 Tuning Condenser
There are currently 4890 online users. [Complete List]
» 2 Member(s) | 4888 Guest(s)
