Philco 60 Alive Again!
Me thinks you got an open winding on the osc coil. Go head and pull it out. Inspect for green spots (rot) and check each winding with and ohm meter. All windings should read a low resistance like less than 10 or 20 ohms.
Philco 60 Alive Again! - by Caperodder - 12-02-2011, 04:04 PM
Re: Philco 60 Alive Again! - by Chicago Jimmy - 12-02-2011, 06:21 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-02-2011, 07:14 PM
Re: Philco 60 Alive Again! - by Phlogiston - 12-02-2011, 07:56 PM
Re: Philco 60 Alive Again! - by Ron Ramirez - 12-02-2011, 08:40 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-02-2011, 09:30 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-02-2011, 09:58 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 09:04 AM
Re: Philco 60 Alive Again! - by gvel - 12-03-2011, 09:09 AM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 09:50 AM
Re: Philco 60 Alive Again! - by 7estatdef - 12-03-2011, 05:19 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 06:05 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 06:45 PM
Re: Philco 60 Alive Again! - by Ron Ramirez - 12-03-2011, 07:27 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 07:34 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 10:06 AM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 11:06 AM
Re: Philco 60 Alive Again! - by morzh - 12-04-2011, 12:46 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 01:16 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 03:05 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 06:37 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 07:04 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 11:49 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:20 AM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 12:11 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 03:46 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 04:12 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 05:53 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 06:25 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 07:20 PM
Re: Philco 60 Still dead - by 7estatdef - 12-05-2011, 10:09 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:01 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:19 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-07-2011, 09:18 AM
91H Code 126 Restore
There are currently 6026 online users. [Complete List]
» 1 Member(s) | 6025 Guest(s)
