Philco 60 Alive Again!
>and measure the resistance from pin 5 of 6A7 to the osc coil pin with the resistor on it. >Should read a low resistance like 20ohms.
Ok something isn't correct. What I had you do was measure across the total primary of the osc coil on the above post.
You said it was 45,000 ohms. This is way too high.
When I look at your drawing all of the resistances look low.
What's up?
Add numbers to the pic doesn't tell me anything as my diagram doesn't have these notation.
Does yours?
Philco 60 Alive Again! - by Caperodder - 12-02-2011, 04:04 PM
Re: Philco 60 Alive Again! - by Chicago Jimmy - 12-02-2011, 06:21 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-02-2011, 07:14 PM
Re: Philco 60 Alive Again! - by Phlogiston - 12-02-2011, 07:56 PM
Re: Philco 60 Alive Again! - by Ron Ramirez - 12-02-2011, 08:40 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-02-2011, 09:30 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-02-2011, 09:58 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 09:04 AM
Re: Philco 60 Alive Again! - by gvel - 12-03-2011, 09:09 AM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 09:50 AM
Re: Philco 60 Alive Again! - by 7estatdef - 12-03-2011, 05:19 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 06:05 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 06:45 PM
Re: Philco 60 Alive Again! - by Ron Ramirez - 12-03-2011, 07:27 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 07:34 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 10:06 AM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 11:06 AM
Re: Philco 60 Alive Again! - by morzh - 12-04-2011, 12:46 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 01:16 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 03:05 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 06:37 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 07:04 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 11:49 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:20 AM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 12:11 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 03:46 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 04:12 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 05:53 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 06:25 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 07:20 PM
Re: Philco 60 Still dead - by 7estatdef - 12-05-2011, 10:09 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:01 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:19 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-07-2011, 09:18 AM
91H Code 126 Restore
