Philco 60 Alive Again!
Hello Terry,
Sorry for not sending a corresponding schematic with my pin numbers. (now included) I must have been reading the incorrect pins when I read the 45k.
One side of the coil should read 3.4 Ohms per schematic (my lugs 2 and 3). I'm getting 3.8 Ohms.
The other side of the coil, going through all of the windings on the schematic are .3, 1.6 and .5 (2.4 Ohms total) I'm reading (my lug 1, with the 51K resistor) and the top of the coil which goes to pin 5 on the 6A7), is 2.6 Ohms.
Forgive my amateur experience, but I don't understand where the 20 Ohms comes from.
-Brett
Philco 60 Alive Again! - by Caperodder - 12-02-2011, 04:04 PM
Re: Philco 60 Alive Again! - by Chicago Jimmy - 12-02-2011, 06:21 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-02-2011, 07:14 PM
Re: Philco 60 Alive Again! - by Phlogiston - 12-02-2011, 07:56 PM
Re: Philco 60 Alive Again! - by Ron Ramirez - 12-02-2011, 08:40 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-02-2011, 09:30 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-02-2011, 09:58 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 09:04 AM
Re: Philco 60 Alive Again! - by gvel - 12-03-2011, 09:09 AM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 09:50 AM
Re: Philco 60 Alive Again! - by 7estatdef - 12-03-2011, 05:19 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 06:05 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 06:45 PM
Re: Philco 60 Alive Again! - by Ron Ramirez - 12-03-2011, 07:27 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 07:34 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 10:06 AM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 11:06 AM
Re: Philco 60 Alive Again! - by morzh - 12-04-2011, 12:46 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 01:16 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 03:05 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 06:37 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 07:04 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 11:49 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:20 AM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 12:11 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 03:46 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 04:12 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 05:53 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 06:25 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 07:20 PM
Re: Philco 60 Still dead - by 7estatdef - 12-05-2011, 10:09 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:01 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:19 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-07-2011, 09:18 AM
91H Code 126 Restore
There are currently 5311 online users. [Complete List]
» 1 Member(s) | 5310 Guest(s)
