OH HECK!
Hello, Bill: Check out the repop glass dial for a model 41-230 offered by Radio Daze. Not sure if it will be the same dimensions, but the scale is similar to yours. Your dial should be 540-1600 KHz/1.6-3.3MHz, and the 41-230 is 540-1600KHz/1.6-3.5MHz.
OH HECK! - by BILL - 12-06-2011, 05:27 PM
Re: OH HECK! - by codefox1 - 12-06-2011, 07:32 PM
Re: OH HECK! - by TA Forbes - 12-06-2011, 09:40 PM
Re: OH HECK! - by Arran - 12-07-2011, 12:12 AM
Re: OH HECK! - by Arran - 12-07-2011, 12:19 AM
Re: OH HECK! - by BILL - 12-07-2011, 04:40 PM
Re: OH HECK! - by TA Forbes - 12-07-2011, 11:13 PM
Philco 91 Tuning Condenser
There are currently 4674 online users. [Complete List]
» 1 Member(s) | 4673 Guest(s)
