OH HECK!
TA Forbes Wrote:Hello, Bill: Check out the repop glass dial for a model 41-230 offered by Radio Daze. Not sure if it will be the same dimensions, but the scale is similar to yours. Your dial should be 540-1600 KHz/1.6-3.3MHz, and the 41-230 is 540-1600KHz/1.6-3.5MHz.
It looks like the dial on the 42-335 has the same coverage if you look at the photo, the font is different but the Police band is also 1.6-3.5 MC so if the dimensions are the same it should be able to track.
OH HECK! - by BILL - 12-06-2011, 05:27 PM
Re: OH HECK! - by codefox1 - 12-06-2011, 07:32 PM
Re: OH HECK! - by TA Forbes - 12-06-2011, 09:40 PM
Re: OH HECK! - by Arran - 12-07-2011, 12:12 AM
Re: OH HECK! - by Arran - 12-07-2011, 12:19 AM
Re: OH HECK! - by BILL - 12-07-2011, 04:40 PM
Re: OH HECK! - by TA Forbes - 12-07-2011, 11:13 PM
Philco 91 Tuning Condenser
There are currently 5004 online users. [Complete List]
» 2 Member(s) | 5002 Guest(s)
