Heathkit tube tester
Hi guys-
I recently acquired a Heathkit model IT-17 tester. I have pretty much figured it out, but there is a switch on the left side that has one position for "leakage" and another for "short" it doesn't seem to have any effect when I test the tubes, and I can't find a manual online anywhere. Anyone have an idea what this switch is used for? The rest of the tester is pretty self explanatory.
Thanks!
Heathkit tube tester - by Paul D - 12-08-2011, 12:43 AM
Re: Heathkit tube tester - by Glenn Roberts - 12-08-2011, 06:25 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6861 online users. [Complete List]
» 1 Member(s) | 6860 Guest(s)
