1000 V Capacitors in 41-250
I just got a unit like this Model 41-280, where can I get capacitors! I can't find the .003 1000 Volt, and what type should I be looking for to replace these wax paper capacitors. Film Axial ? I really need help with this project.
Also, I lose volume when I use both #41 tubes, but works with just one tube, sounds better but not at full strength.
Anyone with this experience?
1000 V Capacitors in 41-250 - by Raleigh - 05-06-2007, 09:56 PM
[No subject] - by Ron Ramirez - 05-13-2007, 02:13 PM
Re: 1000 V Capacitors in 41-250 - by OldJack1969 - 12-08-2011, 05:59 PM
Re: 1000 V Capacitors in 41-250 - by exray - 12-08-2011, 08:15 PM
Re: 1000 V Capacitors in 41-250 - by Ron Ramirez - 12-09-2011, 08:41 PM
Re: 1000 V Capacitors in 41-250 - by codefox1 - 12-10-2011, 12:30 AM
Re: 1000 V Capacitors in 41-250 - by Texasrocker - 12-10-2011, 01:26 AM
Re: 1000 V Capacitors in 41-250 - by Marsupial - 12-10-2011, 05:24 PM
Re: 1000 V Capacitors in 41-250 - by exray - 12-10-2011, 06:18 PM
91H Code 126 Restore
There are currently 5612 online users. [Complete List]
» 1 Member(s) | 5611 Guest(s)
