Value of caps in block?????
Here the link to Chuck's site with alot of block info :
http://www.philcorepairbench.com/bblokcap.htm
Glenn
Happily back in Illinois..not.
Value of caps in block????? - by Dan Walker - 11-16-2011, 04:19 PM
Re: Value of caps in block????? - by Ron Ramirez - 11-16-2011, 06:09 PM
Re: Value of caps in block????? - by Dan Walker - 11-16-2011, 06:53 PM
Re: Value of caps in block????? - by Ron Ramirez - 11-16-2011, 08:23 PM
Re: Value of caps in block????? - by Texasrocker - 11-16-2011, 09:39 PM
Re: Value of caps in block????? - by LASJayhawk - 12-08-2011, 10:15 PM
Re: Value of caps in block????? - by Ron Ramirez - 12-09-2011, 06:32 AM
Re: Value of caps in block????? - by Glenn Roberts - 12-09-2011, 11:22 AM
Re: Value of caps in block????? - by DeckApe - 12-11-2011, 12:54 PM
91H Code 126 Restore
