Simplex model H AC
I have owned a Simplex model H AC (circa 1931?) cathedral radio since the late 70's. Power cord is missing as well as the tubes, (3) 24's, (1) 45 and (1) 80. Front bezel surrounding tuning thumbwheel says "Clearcut", possibly a private label brand? Any info you can shed on this radio? I have photos I can email if anyone is interested. Thanks
Radioman1950
Simplex model H AC - by RADIOMAN1950 - 12-09-2011, 05:01 PM
Re: Simplex model H AC - by John R - 12-09-2011, 05:40 PM
Re: Simplex model H AC - by 7estatdef - 12-09-2011, 11:38 PM
Re: Simplex model H AC - by 7estatdef - 12-12-2011, 01:46 PM
Re: Simplex model H AC - by Jayce - 12-12-2011, 10:49 PM
There are currently 9129 online users. [Complete List]
» 3 Member(s) | 9126 Guest(s)
