Philco 42-345 vid with antenna attachment
Yes, better than not having enough work for sure. Seems I spend more time doing "damage control" than most anything else. And I also need to address having at an ever growing pile of radios and will have to implement some self discipline doing so.
Mike
Re: Philco 42-345 vid with antenna attachment - by Michael Dennis - 12-10-2011, 08:23 PM
Philco 91 Tuning Condenser
There are currently 4537 online users. [Complete List]
» 2 Member(s) | 4535 Guest(s)
