re-wiring RCA 816k
Working on my old 816k and want to replace the cracking rubber coated wires.
What would be the best wire to use?
18 or 20 gauge?
Cloth coated or rubber coated?
Where is the best supplier for wire?
Thanks
murf
re-wiring RCA 816k - by murf - 12-11-2011, 02:07 PM
Re: re-wiring RCA 816k - by Glenn Roberts - 12-11-2011, 03:48 PM
Re: re-wiring RCA 816k - by murf - 12-11-2011, 05:11 PM
Re: re-wiring RCA 816k - by exray - 12-11-2011, 07:03 PM
Re: re-wiring RCA 816k - by Arran - 12-13-2011, 03:17 AM
Re: re-wiring RCA 816k - by mukerjea - 12-16-2011, 06:17 PM
There are currently 8514 online users. [Complete List]
» 1 Member(s) | 8513 Guest(s)
