Source for speaker grill cloth for model 70
Here's the story.
http://www.philcoradio.com/phorum/showth...p?tid=3606
Re: Source for speaker grill cloth for model 70 - by Ron Ramirez - 12-11-2011, 04:25 PM
Philco 91 Tuning Condenser
There are currently 5141 online users. [Complete List]
» 1 Member(s) | 5140 Guest(s)
