Philco 37-630 Chassis Mounts
Hello, looking for information on exactly the 37-630 chassis mounted to the cabinet. Rubber bushings, springs or a combination? I did a forum search but didn't find anything yet. Can anyone help? Thank you!
Philco 37-630 Chassis Mounts - by markskala - 12-11-2011, 10:07 PM
Re: Philco 37-630 Chassis Mounts - by mukerjea - 12-11-2011, 11:07 PM
Re: Philco 37-630 Chassis Mounts - by TA Forbes - 12-11-2011, 11:10 PM
Re: Philco 37-630 Chassis Mounts - by mukerjea - 12-11-2011, 11:19 PM
Re: Philco 37-630 Chassis Mounts - by markskala - 12-11-2011, 11:49 PM
Re: Philco 37-630 Chassis Mounts - by gvel - 12-12-2011, 07:09 PM
Re: Philco 37-630 Chassis Mounts - by markskala - 12-12-2011, 07:09 PM
Re: Philco 37-630 Chassis Mounts - by BDM - 12-13-2011, 01:54 PM
Re: Philco 37-630 Chassis Mounts - by markskala - 12-14-2011, 08:02 PM
Re: Philco 37-630 Chassis Mounts - by BDM - 12-14-2011, 08:09 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
