US Gloritone
Yes,
U.S. Radio & Television made the Gloritone and Apex sets plus a lot of the Airline sets for Monkey Wards. They were located in Marion, Ind. before being bought out by Grunow in '33' located in Chicago.
US Gloritone - by Jayce - 12-11-2011, 10:50 PM
Re: US Gloritone - by Jayce - 12-12-2011, 09:12 PM
Re: US Gloritone - by John R - 12-13-2011, 12:59 AM
Re: US Gloritone - by Jayce - 12-13-2011, 03:44 PM
There are currently 9715 online users. [Complete List]
» 1 Member(s) | 9714 Guest(s)
