Philco 97
The 97 is a fairly uncommon set. Not sure what you mean about the pilot light set up not being all there.
The "window" is a shadow meter, it gives a visual indication for more precise tuning. If it doesn't light up, the bulb is probably not working.
Philco 97 - by nzbhoy - 12-13-2011, 08:49 PM
Re: Philco 97 - by TA Forbes - 12-14-2011, 01:40 AM
Re: Philco 97 - by nzbhoy - 12-14-2011, 04:27 AM
Re: Philco 97 - by rocketeer - 12-14-2011, 10:37 AM
Re: Philco 97 - by TA Forbes - 12-14-2011, 02:49 PM
Philco 91 Tuning Condenser
There are currently 4952 online users. [Complete List]
» 2 Member(s) | 4950 Guest(s)
