Philco 97
hank you for the info regardingthe shadow meter I just cant understand after looking at the pilot light set up how that works or should light up by bettr tuning
Philco 97 - by nzbhoy - 12-13-2011, 08:49 PM
Re: Philco 97 - by TA Forbes - 12-14-2011, 01:40 AM
Re: Philco 97 - by nzbhoy - 12-14-2011, 04:27 AM
Re: Philco 97 - by rocketeer - 12-14-2011, 10:37 AM
Re: Philco 97 - by TA Forbes - 12-14-2011, 02:49 PM
Philco 91 Tuning Condenser
There are currently 4688 online users. [Complete List]
» 1 Member(s) | 4687 Guest(s)
