Philco model 42-1009
First I would like to thank Clumsyowl For the opportunity To soon own this beautiful radio I am looking forward to its restoration and giving it a good home! Here are some pictures of it and any help in info on it to restore it would be much appreciated Thanks .. Doug
[Image: http://i1095.photobucket.com/albums/i474...io202a.jpg]
[Image: http://i1095.photobucket.com/albums/i474...io201a.jpg]
Philco model 42-1009 - by fixinmyphilco - 12-14-2011, 08:12 PM
Re: Philco model 42-1009 - by Marsupial - 12-14-2011, 10:42 PM
Re: Philco model 42-1009 - by Ron Ramirez - 12-15-2011, 08:19 AM
Re: Philco model 42-1009 - by fixinmyphilco - 12-15-2011, 09:00 PM
Re: Philco model 42-1009 - by fixinmyphilco - 12-31-2011, 09:38 AM
Philco 91 Tuning Condenser
There are currently 5896 online users. [Complete List]
» 3 Member(s) | 5893 Guest(s)
