The "Other" Philco Grandfather clock
Hi,
Ok, I found a photo. It's on page 195 of Slusser's 6th edition. Stated as a model 70 & from what I can see of it the escutcheon and knob layout looks correct.
I thought I had seen a photo of this way before the 6th edition appeared, but maybe not.
Not sure if I should make & post a scan of it or not (copyright reasons)...
The "Other" Philco Grandfather clock - by PTurney - 10-24-2006, 12:28 PM
[No subject] - by Chuck Schwark - 10-24-2006, 12:43 PM
[No subject] - by PTurney - 10-24-2006, 01:29 PM
[No subject] - by PTurney - 10-24-2006, 01:57 PM
[No subject] - by Chuck Schwark - 10-24-2006, 02:15 PM
[No subject] - by PTurney - 10-24-2006, 02:43 PM
[No subject] - by PTurney - 10-26-2006, 09:53 AM
[No subject] - by Jerry Huelsbeck - 10-28-2006, 09:29 PM
[No subject] - by Ron Ramirez - 10-30-2006, 10:44 AM
[No subject] - by PTurney - 10-30-2006, 01:58 PM
Philco 91 Tuning Condenser
There are currently 9952 online users. [Complete List]
» 2 Member(s) | 9950 Guest(s)
