Finally got one!
Thank you for the heads up! I plan to get a few sets just to be sure. This set sure appears to be in great condition, and I can't wait to get it!
tractorforum.com *** I reserve the right to be wrong
Finally got one! - by Music in a bottle - 12-15-2011, 03:39 PM
Re: Finally got one! - by TA Forbes - 12-15-2011, 06:21 PM
Re: Finally got one! - by Music in a bottle - 12-15-2011, 11:46 PM
Re: Finally got one! - by Arran - 12-16-2011, 01:27 AM
Re: Finally got one! - by codefox1 - 12-16-2011, 04:28 PM
Re: Finally got one! - by Fred R - 12-24-2011, 04:47 PM
Philco 91 Tuning Condenser
There are currently 4894 online users. [Complete List]
» 2 Member(s) | 4892 Guest(s)
