So I'm just curious guys..... If you got a radio that works fine, is there a wayu to determine that everything is fine in terms of the enternals, or is it a must to just go ahead and replace everything as far as the caps go......
tractorforum.com *** I reserve the right to be wrong
37-623 - by JGerhardt - 12-14-2011, 03:32 AM
Re: 37-623 - by Chuck Schwark - 12-14-2011, 02:01 PM
Re: 37-623 - by TA Forbes - 12-14-2011, 03:04 PM
Re: 37-623 - by 7estatdef - 12-14-2011, 06:06 PM
Re: 37-623 - by Ron Ramirez - 12-14-2011, 06:44 PM
Re: 37-623 - by Music in a bottle - 12-16-2011, 12:54 AM
Re: 37-623 - by Arran - 12-16-2011, 02:20 AM
Re: 37-623 - by BDM - 12-16-2011, 03:05 AM
Re: 37-623 - by codefox1 - 12-16-2011, 04:20 PM
Re: 37-623 - by Arran - 12-16-2011, 10:56 PM
Re: 37-623 - by BDM - 12-16-2011, 11:30 PM
Philco 91 Tuning Condenser
There are currently 4575 online users. [Complete List]
» 2 Member(s) | 4573 Guest(s)
