Phun With Philco 80
Ok I picked up a 80 (on ebay) nice cabinet, but the usual trashed chassis.
it leads to many questions. The layout of the block capacitors is way more like the 81 in riders #3 than the 80... but it's an 80 I'm guessing a later revision chassis?
The output transformer for the audio amp was bad, I subbed in one I had on hand, a small merit A-3025. It's rated at 2500/3.2 ohms, 50ma, 3w. Is that big enough?
The grid lead for the 36 detector/oscillator was missing (as in gone!) I assume it came through the antenna coil can and was tied on to the bottom of the coil?
both 36's test very weak. I know these radios were 'touchy' when new, but would weak 36's keep it from working at all?
after adding a lead for the det/osc grid,the output transformer, and replacing the filter caps I have not much, if i touch the grid of the 2nd det i get some 60 cycle hum but thats about it. My next move is to replace the block caps as they all look like they have run hot, but should I get some 36's on order?
John
Las Vegas, NV USA
Phun With Philco 80 - by LASJayhawk - 12-16-2011, 01:44 AM
Re: Phun With Philco 80 - by BDM - 12-16-2011, 02:41 PM
Re: Phun With Philco 80 - by 7estatdef - 12-16-2011, 05:22 PM
Re: Phun With Philco 80 - by LASJayhawk - 12-16-2011, 07:37 PM
Re: Phun With Philco 80 - by Texasrocker - 12-16-2011, 11:25 PM
Re: Phun With Philco 80 - by LASJayhawk - 12-17-2011, 01:05 AM
Re: Phun With Philco 80 - by 7estatdef - 01-09-2012, 09:58 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 7496 online users. [Complete List]
» 1 Member(s) | 7495 Guest(s)
