Phun With Philco 80
OT should be fine. Replace caps and check resistors particularly 10k and the 1 meg at the detector tube. Would replace the 36's it's bad enough trying to fix one of these with good toobs. Check the feedback coil for the oscillator.
Phun With Philco 80 - by LASJayhawk - 12-16-2011, 01:44 AM
Re: Phun With Philco 80 - by BDM - 12-16-2011, 02:41 PM
Re: Phun With Philco 80 - by 7estatdef - 12-16-2011, 05:22 PM
Re: Phun With Philco 80 - by LASJayhawk - 12-16-2011, 07:37 PM
Re: Phun With Philco 80 - by Texasrocker - 12-16-2011, 11:25 PM
Re: Phun With Philco 80 - by LASJayhawk - 12-17-2011, 01:05 AM
Re: Phun With Philco 80 - by 7estatdef - 01-09-2012, 09:58 AM
91H Code 126 Restore
There are currently 4923 online users. [Complete List]
» 1 Member(s) | 4922 Guest(s)
