Philco 91B Questions
If the 80 is missing (4 pins on bottom of tube) the good news is that you probably did not hurt anything turning it on. The bad news is - it will not work with the 80 missing it is the rectifier for the high voltage - no high voltage - no work. If there are 2 42s in push pull it will work with one missing.
Where are you located?
Philco 91B Questions - by Greg Hyduke - 12-18-2011, 06:06 PM
Re: Philco 91B Questions - by Greg Hyduke - 12-18-2011, 08:44 PM
Re: Philco 91B Questions - by Phlogiston - 12-18-2011, 08:46 PM
Re: Philco 91B Questions - by Greg Hyduke - 12-18-2011, 09:25 PM
Re: Philco 91B Questions - by codefox1 - 12-18-2011, 09:32 PM
Re: Philco 91B Questions - by Greg Hyduke - 12-18-2011, 11:47 PM
Re: Philco 91B Questions - by Phlogiston - 12-19-2011, 12:31 AM
Re: Philco 91B Questions - by Greg Hyduke - 12-19-2011, 12:05 PM
Re: Philco 91B Questions - by Phlogiston - 12-19-2011, 01:53 PM
Re: Philco 91B Questions - by Greg Hyduke - 12-19-2011, 03:19 PM
Re: Philco 91B Questions - by codefox1 - 12-19-2011, 03:35 PM
Re: Philco 91B Questions - by Greg Hyduke - 12-19-2011, 03:47 PM
Re: Philco 91B Questions - by Ron Ramirez - 12-19-2011, 05:30 PM
Re: Philco 91B Questions - by Ron Ramirez - 12-19-2011, 05:31 PM
Re: Philco 91B Questions - by Greg Hyduke - 12-19-2011, 06:30 PM
Philco 91 Tuning Condenser
There are currently 4930 online users. [Complete List]
» 2 Member(s) | 4928 Guest(s)
