Grill Cloth for Philco 41-280
I am restoring a Philco model 41-280 and I am wondering what type of grill cloth was used at the time of manufactering. I also would like to know if anyone knows fo anywhere to get the chassis overhauled. I mainly just know about cabinet restoration and not anything about the chassis.
Grill Cloth for Philco 41-280 - by jsa-294 - 12-18-2011, 10:46 PM
Re: Grill Cloth for Philco 41-280 - by RFP - 12-19-2011, 10:30 AM
There are currently 9449 online users. [Complete List]
» 5 Member(s) | 9444 Guest(s)
AvatarAvatarAvatarAvatar
