Alignment tool for Philco 70A trimmer capacitors
reviving a very old thread.
I'm messing with using 1/4" PEX (used for plumbing out here, about $1.60 for 4' here in vegas at lowes.)
My addition to the whole thing is instead of using a nut to put the hex into the tubing, I'm using a 1/4" allen wrench. using the long arm of the allen wrench gives you a 3" long 1/4" shank to drive into the tool, and the short arm makes for a good handle while working making the tool.
I'm trying to find a good way to heat the PEX instead of the tool to make it easier to form the tool.
John
Las Vegas, NV USA
Alignment tool for Philco 70A trimmer capacitors - by Guest - 01-30-2006, 02:00 PM
[No subject] - by Chuck Schwark - 01-30-2006, 03:26 PM
[No subject] - by Guest - 01-31-2006, 10:47 AM
[No subject] - by Chuck Schwark - 01-31-2006, 10:52 AM
[No subject] - by Guest - 01-31-2006, 05:30 PM
[No subject] - by n9vu - 02-06-2006, 11:25 PM
[No subject] - by Chuck Schwark - 02-06-2006, 11:36 PM
Re: Alignment tool for Philco 70A trimmer capacitors - by LASJayhawk - 12-18-2011, 11:48 PM
91H Code 126 Restore
