tube very hot philco 42-1013
It could be that the rectifier was replaced with modern diodes underneath the chassis. Unless other measures are taken sometimes that leads to higher voltages and may be related to overheating. But if you're referring to the audio output tube it runs quite hot in normal operation.
BTW, "leaky" caps refer to internal leakage not necessarily visible from the outside. If they are the original paper caps they probably are leaky and should be replaced if you're going to use the radio often.
tube very hot philco 42-1013 - by magicclocks - 12-18-2011, 05:27 PM
Re: tube very hot philco 42-1013 - by exray - 12-19-2011, 06:46 AM
Re: tube very hot philco 42-1013 - by magicclocks - 12-19-2011, 08:36 AM
Re: tube very hot philco 42-1013 - by LASJayhawk - 12-20-2011, 12:44 AM
91H Code 126 Restore
There are currently 5556 online users. [Complete List]
» 1 Member(s) | 5555 Guest(s)
