restoring my philco 42-1013 some pictures
yes I noticed that beam of light was supposed to be something special I read. but anyways it works great waiting for two belts to get all the speeds working the 78 works right off the drive shaft but the other speeds use the belts and their both stretched out but I cant stop looking at it I love it
Re: restoring my philco 42-1013 some pictures - by magicclocks - 12-19-2011, 09:39 PM
