tube very hot philco 42-1013
yes the 630v caps will be fine in almost every application. It's about all I use anymore less parts to keep around and modern caps are smaller than the 70 year old ones.
John
Las Vegas, NV USA
tube very hot philco 42-1013 - by magicclocks - 12-18-2011, 05:27 PM
Re: tube very hot philco 42-1013 - by exray - 12-19-2011, 06:46 AM
Re: tube very hot philco 42-1013 - by magicclocks - 12-19-2011, 08:36 AM
Re: tube very hot philco 42-1013 - by LASJayhawk - 12-20-2011, 12:44 AM
91H Code 126 Restore
Philco 70 antenna lead
