Philco 87 alignment question/RESULTS
The "volume control" on the 87 is just a 10K potentiometer connected between the antenna terminal and ground. On sets like these, a good ground is essential for proper operation of the volume control. Left ungrounded, the volume control is not always effective on strong local stations, as you have discovered.
Re: Philco 87 alignment question - by Ron Ramirez - 01-21-2012, 06:00 PM
Re: Philco 87 alignment question - by DKinYORKpa - 01-21-2012, 06:41 PM
Re: Philco 87 alignment question - by Ron Ramirez - 01-21-2012, 09:18 PM
Re: Philco 87 alignment question - by DKinYORKpa - 01-22-2012, 11:58 AM
91H Code 126 Restore
