Model 91 alignment
I don't know if I'm too tired to see the obvious, but I'm having trouble finding an alignment procedure for the model 91 cathedral. It's the standard model, 110 volt, single speaker, code 123. Can anyone help??
Thanks in advance
Model 91 alignment - by theblurrrr - 10-27-2006, 04:17 AM
Never mind guys - by theblurrrr - 10-28-2006, 01:11 PM
