RCA 128 finished
Outstanding!! What a beautiful set [Image: http://i12.photobucket.com/albums/a223/a.../drool.gif]
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
RCA 128 finished - by 37silverstreak - 12-19-2011, 09:49 PM
Re: RCA 128 finished - by Ron Ramirez - 12-19-2011, 10:16 PM
Re: RCA 128 finished - by Steve Davis - 12-19-2011, 10:49 PM
Re: RCA 128 finished - by TA Forbes - 12-19-2011, 11:04 PM
Re: RCA 128 finished - by thirtiesradio - 12-21-2011, 04:03 AM
Re: RCA 128 finished - by Uffda - 12-21-2011, 01:02 PM
Re: RCA 128 finished - by BDM - 12-26-2011, 03:45 AM
Re: RCA 128 finished - by Chicago Jimmy - 12-26-2011, 06:17 PM
Re: RCA 128 finished - by Texasrocker - 12-30-2011, 12:35 AM
Re: RCA 128 finished - by Arran - 12-30-2011, 05:59 PM
Re: RCA 128 finished - by 37silverstreak - 12-30-2011, 11:51 PM
Re: RCA 128 finished - by Arran - 01-02-2012, 04:08 AM
Re: RCA 128 finished - by 37silverstreak - 01-02-2012, 02:24 PM
There are currently 10599 online users. [Complete List]
» 2 Member(s) | 10597 Guest(s)
