The "Other" Philco Grandfather clock
Thats a nice looking radio (the ebay link) as well, however the "capasitators" are bad! Icon_biggrin
The "Other" Philco Grandfather clock - by PTurney - 10-24-2006, 12:28 PM
[No subject] - by Chuck Schwark - 10-24-2006, 12:43 PM
[No subject] - by PTurney - 10-24-2006, 01:29 PM
[No subject] - by PTurney - 10-24-2006, 01:57 PM
[No subject] - by Chuck Schwark - 10-24-2006, 02:15 PM
[No subject] - by PTurney - 10-24-2006, 02:43 PM
[No subject] - by PTurney - 10-26-2006, 09:53 AM
[No subject] - by Jerry Huelsbeck - 10-28-2006, 09:29 PM
[No subject] - by Ron Ramirez - 10-30-2006, 10:44 AM
[No subject] - by PTurney - 10-30-2006, 01:58 PM
Philco 91 Tuning Condenser
There are currently 10149 online users. [Complete List]
» 3 Member(s) | 10146 Guest(s)
