71 code 125
Thanks Steve, but I'm going to hold on to this one. It may be a while before I get started restoring it, got some other projects to finish up first. This is my first Philco & my first pre-war set. I'm looking forward to working on it.
Dave
71 code 125 - by Dave - 12-31-2011, 04:43 PM
Re: 71 code 121 - by 7estatdef - 12-31-2011, 05:30 PM
Re: 71 code 121 - by Steve Davis - 12-31-2011, 06:05 PM
Re: 71 code 121 - by Dave - 12-31-2011, 06:28 PM
Re: 71 code 125 - by 7estatdef - 12-31-2011, 09:01 PM
Re: 71 code 125 - by Dave - 12-31-2011, 09:38 PM
Re: 71 code 125 - by TA Forbes - 01-01-2012, 08:51 PM
Re: 71 code 125 - by Dave - 01-01-2012, 09:37 PM
Re: 71 code 125 - by TA Forbes - 01-02-2012, 07:23 PM
Re: 71 code 125 - by Ron Ramirez - 01-02-2012, 08:09 PM
Re: 71 code 125 - by TA Forbes - 01-02-2012, 11:18 PM
Re: 71 code 125 - by Dave - 01-04-2012, 11:54 AM
Re: 71 code 125 - by TA Forbes - 01-04-2012, 01:25 PM
Re: 71 code 125 - by Dave - 01-04-2012, 02:01 PM
Philco 91 Tuning Condenser
There are currently 4637 online users. [Complete List]
» 1 Member(s) | 4636 Guest(s)
