coronado console mid 30,s
I bought an RCA K130 a few years ago at the flea market for $65 if I remember right. It was complete and had a good original finish except for one place on the top where the finish had been removed. I think I would pay $75 for another. It does have 13 tubes including an eye and has motorized push button tuning. However, 8 of the remaining 12 tubes are the rectifiers and audio drivers and outputs. It also had rubber wiring that will need to be replaced.
Sean
WØKPX
coronado console mid 30,s - by murf - 12-31-2011, 05:39 PM
Re: coronado console mid 30,s - by Carl Travis - 12-31-2011, 07:06 PM
Re: coronado console mid 30,s - by Sean - 01-01-2012, 09:29 AM
Re: coronado console mid 30,s - by TA Forbes - 01-01-2012, 09:15 PM
Re: coronado console mid 30,s - by Arran - 01-02-2012, 04:21 AM
There are currently 10549 online users. [Complete List]
» 3 Member(s) | 10546 Guest(s)
