71 code 125
Thanks, that may save me a bunch of time. I dropped the radio off at my office, so I'll get some measurements when I get back to work on Tuesday. I'm hoping that the 42 tube still works, it's an original Philco tube but the base is loose.
Dave
71 code 125 - by Dave - 12-31-2011, 04:43 PM
Re: 71 code 121 - by 7estatdef - 12-31-2011, 05:30 PM
Re: 71 code 121 - by Steve Davis - 12-31-2011, 06:05 PM
Re: 71 code 121 - by Dave - 12-31-2011, 06:28 PM
Re: 71 code 125 - by 7estatdef - 12-31-2011, 09:01 PM
Re: 71 code 125 - by Dave - 12-31-2011, 09:38 PM
Re: 71 code 125 - by TA Forbes - 01-01-2012, 08:51 PM
Re: 71 code 125 - by Dave - 01-01-2012, 09:37 PM
Re: 71 code 125 - by TA Forbes - 01-02-2012, 07:23 PM
Re: 71 code 125 - by Ron Ramirez - 01-02-2012, 08:09 PM
Re: 71 code 125 - by TA Forbes - 01-02-2012, 11:18 PM
Re: 71 code 125 - by Dave - 01-04-2012, 11:54 AM
Re: 71 code 125 - by TA Forbes - 01-04-2012, 01:25 PM
Re: 71 code 125 - by Dave - 01-04-2012, 02:01 PM
Philco 91 Tuning Condenser
There are currently 4783 online users. [Complete List]
» 1 Member(s) | 4782 Guest(s)
