The gift supreme for Christmas - a Philco - 2011 Version
gvel Wrote:I really like that cabinet!
I'm far from an appraiser - but ordinarily wouldn't that radio go for a bit more?
You may be getting that model mixed up with one of the Bullet styled 37 or 38-620s which are similarly styled.
Philco 91 Tuning Condenser
There are currently 5428 online users. [Complete List]
» 1 Member(s) | 5427 Guest(s)
