Alignment instructions needed
The only thing that seems a bit odd is putting the signal generator output into the grid of the osc. Try the grid cap of the mixer tube for the IF. Double check that the trimmer that you where adjusting IS connected to the circuit that you are adjusting. Sometimes on these old sets the trimmer may not be located near the coil its tuning.
Alignment instructions needed - by ipwizard - 01-01-2012, 05:18 PM
Re: Alignment instructions needed - by 7estatdef - 01-02-2012, 01:04 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 12:45 AM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 01:14 AM
Re: Alignment instructions needed - by 7estatdef - 01-04-2012, 07:31 AM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 01:46 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 05:55 PM
Re: Alignment instructions needed - by 7estatdef - 01-04-2012, 07:16 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 08:50 PM
Re: Alignment instructions needed - by 7estatdef - 01-04-2012, 11:12 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 11:46 PM
Re: Alignment instructions needed - by 7estatdef - 01-05-2012, 12:16 AM
Re: Alignment instructions needed - by ipwizard - 01-05-2012, 01:42 AM
Re: Alignment instructions needed - by ipwizard - 01-05-2012, 02:00 PM
Re: Alignment instructions needed - by 7estatdef - 01-05-2012, 07:14 PM
Re: Alignment instructions needed - by ipwizard - 01-06-2012, 12:57 AM
Re: Alignment instructions needed - by John R - 01-06-2012, 01:29 PM
Re: Alignment instructions needed - by ipwizard - 01-09-2012, 12:31 AM
Re: Alignment instructions needed - by 7estatdef - 01-09-2012, 09:23 AM
Re: Alignment instructions needed - by ipwizard - 01-09-2012, 01:56 PM
Re: Alignment instructions needed - by ipwizard - 01-11-2012, 12:33 AM
Re: Alignment instructions needed - by ipwizard - 01-13-2012, 01:41 AM
91H Code 126 Restore
There are currently 2621 online users. [Complete List]
» 1 Member(s) | 2620 Guest(s)
