Philco Tropic Radio 48-821 code 121
Good morning,
RMS (Radio Manufacturers Service) did not return after World War II. Instead, it became PHILCO SERVICE.
Philco published, and I have a copy of, a 1946-47 Home Radio Yearbook that gives the schematics for all of the 1946-47 models. As I recall, I do not believe it gives any Tropic schematics (800 series). But I am not in a position to check my copy right now - it's at home and I am not.
Chuck...you have a copy too, don't you? Can you look and see, please? Thanks.
Philco Tropic Radio 48-821 code 121 - by Guest - 03-06-2006, 10:23 AM
[No subject] - by Guest - 10-31-2006, 09:00 AM
[No subject] - by Ron Ramirez - 10-31-2006, 09:47 AM
[No subject] - by Chuck Schwark - 10-31-2006, 09:55 AM
[No subject] - by Ron Ramirez - 11-09-2006, 09:40 AM
philco tropic - by Guest - 07-04-2007, 09:25 AM
Eico 232 VTVM Schematic
There are currently 10041 online users. [Complete List]
» 1 Member(s) | 10040 Guest(s)
