Philco 41-280
Ok pull out one of the 41 tubes and look at the bottom. You will see an arrow that is between two fatter pins. Starting at the fat pin to the left of the arrow is pin 1 counting clockwise ending at the other fat pin which is pin 6.
What you want to do is measure voltage at the socket with all the tubes in place and on and running. - lead to the chassis + lead measure the voltage on pins 2 and 3 of both 41 tubes. Should have about 200vdc on all four of these pins. Do you?
Philco 41-280 - by OldJack1969 - 01-03-2012, 07:08 PM
Re: Philco 41-280 - by 7estatdef - 01-03-2012, 08:52 PM
Re: Philco 41-280 - by OldJack1969 - 01-04-2012, 06:55 PM
Re: Philco 41-280 - by 7estatdef - 01-04-2012, 11:49 PM
Re: Philco 41-280 - by OldJack1969 - 01-05-2012, 12:00 AM
Re: Philco 41-280 - by OldJack1969 - 01-05-2012, 01:09 AM
Re: Philco 41-280 - by 7estatdef - 01-05-2012, 07:28 PM
Re: Philco 41-280 - by OldJack1969 - 01-05-2012, 08:25 PM
Re: Philco 41-280 - by 7estatdef - 01-05-2012, 11:28 PM
Re: Philco 41-280 - by OldJack1969 - 01-06-2012, 12:05 AM
Re: Philco 41-280 - by 7estatdef - 01-06-2012, 08:47 AM
Re: Philco 41-280 - by OldJack1969 - 01-06-2012, 01:35 PM
Re: Philco 41-280 - by 7estatdef - 01-06-2012, 05:42 PM
Re: Philco 41-280 - by OldJack1969 - 01-08-2012, 12:43 AM
Re: Philco 41-280 - by Phlogiston - 01-08-2012, 12:56 AM
Re: Philco 41-280 - by OldJack1969 - 01-08-2012, 01:10 AM
Re: Philco 41-280 - by 7estatdef - 01-08-2012, 03:30 PM
Re: Philco 41-280 - by OldJack1969 - 01-08-2012, 03:45 PM
Re: Philco 41-280 - by gary rabbitt - 01-23-2012, 08:38 PM
Re: Philco 41-280 - by OldJack1969 - 01-23-2012, 09:29 PM
Re: Philco 41-280 - by gary rabbitt - 01-24-2012, 04:58 PM
Re: Philco 41-280 - by OldJack1969 - 01-24-2012, 05:10 PM
Re: Philco 41-280 - by 7estatdef - 01-24-2012, 06:17 PM
Re: Philco 41-280 - by OldJack1969 - 01-24-2012, 06:50 PM
Re: Philco 41-280 - by 7estatdef - 01-24-2012, 06:56 PM
Re: Philco 41-280 - by OldJack1969 - 01-24-2012, 07:15 PM
91H Code 126 Restore
There are currently 4549 online users. [Complete List]
» 1 Member(s) | 4548 Guest(s)
