Philco 41-280
OldJack1969 Wrote:
7estatdef Wrote:Ok pull out one of the 41 tubes and look at the bottom. You will see an arrow that is between two fatter pins. Starting at the fat pin to the left of the arrow is pin 1 counting clockwise ending at the other fat pin which is pin 6.
What you want to do is measure voltage at the socket with all the tubes in place and on and running. - lead to the chassis + lead measure the voltage on pins 2 and 3 of both 41 tubes. Should have about 200vdc on all four of these pins. Do you?
I'll get back to you tomorrow and let you know.. Thanks
Ok, if I'm doing this right, I have one lead on the chassis and one lead to pin 2 and then 3 right? I'm getting 129 Volts and 124 Volts and on the other tube I'm getting 124 V and 112 Volts....
Philco 41-280 - by OldJack1969 - 01-03-2012, 07:08 PM
Re: Philco 41-280 - by 7estatdef - 01-03-2012, 08:52 PM
Re: Philco 41-280 - by OldJack1969 - 01-04-2012, 06:55 PM
Re: Philco 41-280 - by 7estatdef - 01-04-2012, 11:49 PM
Re: Philco 41-280 - by OldJack1969 - 01-05-2012, 12:00 AM
Re: Philco 41-280 - by OldJack1969 - 01-05-2012, 01:09 AM
Re: Philco 41-280 - by 7estatdef - 01-05-2012, 07:28 PM
Re: Philco 41-280 - by OldJack1969 - 01-05-2012, 08:25 PM
Re: Philco 41-280 - by 7estatdef - 01-05-2012, 11:28 PM
Re: Philco 41-280 - by OldJack1969 - 01-06-2012, 12:05 AM
Re: Philco 41-280 - by 7estatdef - 01-06-2012, 08:47 AM
Re: Philco 41-280 - by OldJack1969 - 01-06-2012, 01:35 PM
Re: Philco 41-280 - by 7estatdef - 01-06-2012, 05:42 PM
Re: Philco 41-280 - by OldJack1969 - 01-08-2012, 12:43 AM
Re: Philco 41-280 - by Phlogiston - 01-08-2012, 12:56 AM
Re: Philco 41-280 - by OldJack1969 - 01-08-2012, 01:10 AM
Re: Philco 41-280 - by 7estatdef - 01-08-2012, 03:30 PM
Re: Philco 41-280 - by OldJack1969 - 01-08-2012, 03:45 PM
Re: Philco 41-280 - by gary rabbitt - 01-23-2012, 08:38 PM
Re: Philco 41-280 - by OldJack1969 - 01-23-2012, 09:29 PM
Re: Philco 41-280 - by gary rabbitt - 01-24-2012, 04:58 PM
Re: Philco 41-280 - by OldJack1969 - 01-24-2012, 05:10 PM
Re: Philco 41-280 - by 7estatdef - 01-24-2012, 06:17 PM
Re: Philco 41-280 - by OldJack1969 - 01-24-2012, 06:50 PM
Re: Philco 41-280 - by 7estatdef - 01-24-2012, 06:56 PM
Re: Philco 41-280 - by OldJack1969 - 01-24-2012, 07:15 PM
91H Code 126 Restore
