Philco 44d,29d,144d,or 118d
I have a chassie from a 45 Philco ,same vintage, don't know if it's the same ? Take a look at it on this sight ,FOR SALE/TRADE, under "PHILCO WRECK OF THE MONTH"
Philco 44d,29d,144d,or 118d - by laurakdoc - 01-04-2012, 03:14 PM
Re: Philco 44d,29d,144d,or 118d - by 7estatdef - 01-04-2012, 11:00 PM
Re: Philco 44d,29d,144d,or 118d - by BILL - 01-06-2012, 10:40 AM
Philco 91 Tuning Condenser
