Philco 38-9k
That pilot lamp socket can be rebuilt.
http://www.philcoradio.com/tech/lamps.htm
Philco 38-9k - by fixinmyphilco - 12-11-2011, 10:01 PM
Re: Philco 38-9k - by TA Forbes - 12-11-2011, 11:07 PM
Re: Philco 38-9k - by TA Forbes - 12-11-2011, 11:32 PM
Re: Philco 38-9k - by fixinmyphilco - 12-12-2011, 07:38 AM
Re: Philco 38-9k - by 7estatdef - 12-12-2011, 01:56 PM
Re: Philco 38-9k - by fixinmyphilco - 12-13-2011, 06:40 AM
Re: Philco 38-9k - by Chicago Jimmy - 12-13-2011, 06:10 PM
Re: Philco 38-9k - by fixinmyphilco - 12-31-2011, 09:40 AM
Re: Philco 38-9k - by fixinmyphilco - 01-07-2012, 07:26 PM
Re: Philco 38-9k - by Ron Ramirez - 01-07-2012, 07:33 PM
Re: Philco 38-9k - by fixinmyphilco - 01-07-2012, 07:42 PM
Re: Philco 38-9k - by fixinmyphilco - 01-08-2012, 02:03 PM
Re: Philco 38-9k - by 7estatdef - 01-08-2012, 03:37 PM
Re: Philco 38-9k - by fixinmyphilco - 01-08-2012, 03:39 PM
Re: Philco 38-9k - by fixinmyphilco - 01-08-2012, 04:37 PM
Re: Philco 38-9k - by fixinmyphilco - 01-10-2012, 08:45 PM
Re: Philco 38-9k - by BDM - 01-12-2012, 01:38 AM
Re: Philco 38-9k - by fixinmyphilco - 01-12-2012, 07:47 AM
Re: Philco 38-9k - by fixinmyphilco - 01-19-2012, 07:56 PM
Re: Philco 38-9k - by fixinmyphilco - 02-11-2012, 07:20 PM
Re: Philco 38-9k - by Chicago Jimmy - 02-11-2012, 09:04 PM
Re: Philco 38-9k - by fixinmyphilco - 02-12-2012, 12:30 PM
Re: Philco 38-9k - by DeckApe - 02-13-2012, 09:33 AM
Re: Philco 38-9k - by fixinmyphilco - 02-14-2012, 10:05 PM
Re: Philco 38-9k - by codefox1 - 02-15-2012, 01:13 PM
Re: Philco 38-9k - by Dave - 02-16-2012, 10:47 PM
Philco 91 Tuning Condenser
There are currently 3642 online users. [Complete List]
» 2 Member(s) | 3640 Guest(s)
