RCA K130 RC501a chassis
Pick up an old RCA K130 yesterday and discovered it needs a new tone control swith.
It has the phenolic busted in about 3 pcs.
Anyone know where I could find one of these?
The motor for the electronic tuning isn't working either.
It will engage the drive wheel,but will not rotate.Just humms.
Anyone have any luck repairing one of these?
Thanks for your help.
murf
RCA K130 RC501a chassis - by murf - 01-08-2012, 02:31 PM
RE: RCA K130 RC501a chassis - by murf - 09-03-2012, 05:12 PM
Re: RCA K130 RC501a chassis - by Sean - 01-08-2012, 03:08 PM
Re: RCA K130 RC501a chassis - by murf - 01-08-2012, 03:17 PM
Re: RCA K130 RC501a chassis - by murf - 01-09-2012, 04:36 PM
Re: RCA K130 RC501a chassis - by Sean - 01-09-2012, 06:00 PM
Re: RCA K130 RC501a chassis - by 7estatdef - 01-09-2012, 09:58 PM
Re: RCA K130 RC501a chassis - by murf - 01-09-2012, 11:04 PM
Re: RCA K130 RC501a chassis - by 7estatdef - 01-09-2012, 11:37 PM
Re: RCA K130 RC501a chassis - by murf - 01-10-2012, 12:09 AM
Re: RCA K130 RC501a chassis - by murf - 01-10-2012, 09:03 PM
Re: RCA K130 RC501a chassis - by Sean - 01-11-2012, 10:47 AM
Re: RCA K130 RC501a chassis - by murf - 01-11-2012, 11:11 AM
Re: RCA K130 RC501a chassis - by murf - 01-11-2012, 03:09 PM
Re: RCA K130 RC501a chassis - by Sean - 01-11-2012, 05:31 PM
Re: RCA K130 RC501a chassis - by murf - 01-11-2012, 07:37 PM
Re: RCA K130 RC501a chassis - by Sean - 01-12-2012, 01:32 PM
Re: RCA K130 RC501a chassis - by murf - 01-12-2012, 02:10 PM
There are currently 5034 online users. [Complete List]
» 1 Member(s) | 5033 Guest(s)
