39-31XF
A good ground may take care of your hum problem. You can also you try unplugging the set and turning the plug around the other way and replugging in.
The antenna consists or a piece of wire, gauge is not too important just so it isn't easily broken. As long and as high outdoors you can get it.
ps You may want to send Ron a pic of it he doesn't have one in the Gallery.
39-31XF - by Jimy - 01-09-2012, 03:19 AM
Re: 39-31XF - by 7estatdef - 01-09-2012, 09:02 AM
Re: 39-31XF - by Jimy - 01-10-2012, 02:56 AM
91H Code 126 Restore
There are currently 3867 online users. [Complete List]
» 1 Member(s) | 3866 Guest(s)
