42-1012 help needed.
It's 455Kc same as the BC band.
42-1012 help needed. - by taxp00rrichard - 01-06-2012, 04:58 PM
Re: 42-1012 help needed. - by codefox1 - 01-06-2012, 05:28 PM
Re: 42-1012 help needed. - by taxp00rrichard - 01-06-2012, 05:40 PM
Re: 42-1012 help needed. - by 7estatdef - 01-06-2012, 06:00 PM
Re: 42-1012 help needed. - by taxp00rrichard - 01-08-2012, 11:05 AM
Re: 42-1012 help needed. - by 7estatdef - 01-09-2012, 09:28 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5841 online users. [Complete List]
» 1 Member(s) | 5840 Guest(s)
