Grandfather clock radio, Model 70
Hi Herb
Welcome to the phourm!
Model 70(chassis) is a fairly common model but there are two different versions of it. There was an early and late version and electrically are very different from each other.
Probably the easiest thing for starters is to do a search in the phourm on Model 70.
I've got the model 370 which is the model 70 in a chairside cabinet. The 70 in a clock cabinet is known as a 570
Grandfather clock radio, Model 70 - by Herbstoy - 01-09-2012, 05:39 PM
Re: Grandfather clock radio, Model 70 - by 7estatdef - 01-09-2012, 06:32 PM
Philco 91 Tuning Condenser
There are currently 5893 online users. [Complete List]
» 3 Member(s) | 5890 Guest(s)
