Possible 37-84
I'd think somewhere around $45 to $75. Buy the time you fix it and replace the dial you'll have another $30 or so. I don't think I'd spend more than $100 for a nice working one and I've got 3 or 4 of them.
Possible 37-84 - by Jayce - 01-10-2012, 05:50 PM
Re: Possible 37-84 - by 7estatdef - 01-10-2012, 07:26 PM
Re: Possible 37-84 - by Jayce - 01-10-2012, 09:14 PM
Re: Possible 37-84 - by 7estatdef - 01-10-2012, 10:20 PM
Re: Possible 37-84 - by Jayce - 01-12-2012, 07:27 PM
Re: Possible 37-84 - by Jayce - 01-19-2012, 03:55 PM
Philco 91 Tuning Condenser
There are currently 5148 online users. [Complete List]
» 1 Member(s) | 5147 Guest(s)
