1936 116X question
Hi Guys, I have just obtained what I believe is a 1936 116X chassis code122. My intention here was to scavenge parts off of it to finish a 116X project in progress. But now, I am not certain what it is that I have. I understand that the company made several changes over the various production runs for this radio. One thing I noticed is that a capacitor block (item 47 on the schematic) is totally omitted and there are subtle differences in wiring. Is there a good resource that lists the various updates and changes along with schematics that match?
Regards to all, Marc.
1936 116X question - by marcus0331 - 01-11-2012, 01:29 PM
Re: 1936 116X question - by BDM - 01-12-2012, 01:41 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3342 online users. [Complete List]
» 2 Member(s) | 3340 Guest(s)
