48-1262 No Sound!
Agreed. I am in the proscess of getting everything together that I will need for the recap and resistor replace. Hopefully that will take care of no sound.
If anyone else has any other guess it would be appreciated also.
While I'm at it, let me ask all of you this. I also have a 40-180 that needs a recap. Is there any parts supply out there where I can tell them what radio I have and have them send me a recap "kit" that would have all the caps I need for my particular radio? Or, do I have to do it the old fashined way and count up how many of each cap value I need by looking in the chasis or the wiring diagram?
48-1262 No Sound! - by GusKoltoukis - 01-11-2012, 12:47 AM
Re: 48-1262 No Sound! - by codefox1 - 01-11-2012, 11:46 AM
Re: 48-1262 No Sound! - by GusKoltoukis - 01-11-2012, 03:42 PM
Re: 48-1262 No Sound! - by John R - 01-11-2012, 05:11 PM
Re: 48-1262 No Sound! - by GusKoltoukis - 01-12-2012, 09:46 AM
Re: 48-1262 No Sound! - by John R - 01-12-2012, 02:49 PM
Re: 48-1262 No Sound! - by Glenn Roberts - 01-12-2012, 04:46 PM
Re: 48-1262 No Sound! - by GusKoltoukis - 01-12-2012, 11:14 PM
Re: 48-1262 No Sound! - by DKinYORKpa - 01-14-2012, 06:39 PM
Re: 48-1262 No Sound! - by GusKoltoukis - 01-15-2012, 12:03 AM
91H Code 126 Restore
